Help to move the actor in android
fabinhoBR
Postby fabinhoBR » Sun Aug 06, 2017 12:36 pm
I am tryng to create a game in android, I try to create a button to when the player press it the player move, but I tried and it doesn´t work, I tried in many ways and nothing, I tried in the HUD interface, the first problema was in the Trigger, I select "Triggers when the mouse button is pressed" but the trigger is not called, it doesn´t start the script in anyway
Sorry for bad english, I am brazilian but the brazilian´s forum is too much unorganized
AnvilHouse
Re: Help to move the actor in android
Postby AnvilHouse » Sun Aug 06, 2017 1:48 pm
So you are trying to make something like a D-Pad?
If so, if you are using the default Input Set titled "Regular Game", you can use the simulate control drop down box in the field editor screen and select the direction you wish the button to move your character.
Image Image Image
https://www.patreon.com/Anvilhouse ...yes...I am on Patreon!
