How should cursors be positioned?
Danny
Postby Danny » Tue Oct 20, 2015 3:51 pm
Ive made a custom cursor but it doesnt click well, it will click above fields when i actually have the tip of the cursor over the field. What values in the sprite editor must i use to position it correctly? I used 13, 0, -13 so it would postion the tip of the cursor directly to the center. :?
Thanks
Not Me
Location: Well... I THINK I'm here... or maybe there...
Re: How should cursors be positioned?
Postby Not Me » Tue Oct 20, 2015 6:26 pm
If I recall correctly, you need to position cursors using the Top or Interface views. I find that it's a good idea to base everything off of Top view whenever possible, just because it causes less silliness.
The above image is totally not a link to my website.
Danny
Postby Danny » Tue Oct 20, 2015 6:37 pm
Works perfectly! Thank you :D
