Movement X & Y Animation Speed Issue
RamchuK_Ntertainment
Ultimate 001 Member
Postby RamchuK_Ntertainment » Thu Feb 16, 2017 4:59 pm
I have a 3D model animation setup for the default 'Walking' pose. Since the default animation on the model is too slow (maximal speed within Blender is still too slow), I adjusted the time scale to be 200. When using Forward/Backward movement, the animation speed is properly adjusted, but Movement X & Y events keep the default animation speed. I've tried changing pose timing (frames per second) without any help. I believe the Movement X & Y events are not taking into consideration the time scale of models. Please confirm.
Travesty: 3D Survival - WIP >>> Forum Topic
University of Washington (BABA)
-REGT- Ramchuk Entertainment Games Team
Strategy/Action/Adventure
Copyrighted©2008-2017
Re: Movement X & Y Animation Speed Issue
Postby Mr.Numbers » Thu Feb 16, 2017 5:02 pm
Can you send a bug report with two simple tests? One with it working with another movement system and one with the movement x/y. Thanks!
Ultimate 001 Member
Postby RamchuK_Ntertainment » Thu Feb 16, 2017 5:10 pm
Scratch that, this was a speedy post; it seems as though it's working properly, I just needed to set a higher time scale, I forgot that default poses take player speed into account, so one must properly adjust for that. Slow actor speeds require higher time scaling... I'll remember for the future. My apologies. :roll:
