Page 1 of 1
view distance WAY too small in 3D mode
PostPosted: Mon Nov 23, 2015 1:24 am
by skullboy99
Hello, So with the help of some kind people on these forums, I am able to make an FPS game. Although, I am having a major issue with something. The view distance is very awful, and is way to hard to see where I'm going. Is it possible to make the view distance farther?
Re: view distance WAY too small in 3D mode
PostPosted: Mon Nov 23, 2015 1:44 am
by AnvilHouse
This is an easy one, you want to up your processing radius and minimum ceiling in game settings
PostPosted: Mon Nov 23, 2015 3:13 am
by skullboy99
AnvilHouse wrote:This is an easy one, you want to up your processing radius and minimum ceiling in game settings
This did make everything in the level load faster, but I still have the same view distance.
PostPosted: Mon Nov 23, 2015 10:20 am
by AnvilHouse
What did you change it to?
PostPosted: Mon Nov 23, 2015 2:54 pm
by skullboy99
AnvilHouse wrote:What did you change it to?
I changed it to 4000, and everything loaded faster as I walked around, but still couldn't see too far. Just to see if it even works, I set it to 1, and I could still see as far as I normally do, just the game was quite framey.
PostPosted: Mon Nov 23, 2015 3:19 pm
by AnvilHouse
Psh I misconstrued the question along with mixing a few things up, just do a Change Distance event under the Camera category
PostPosted: Mon Nov 23, 2015 3:52 pm
by skullboy99
AnvilHouse wrote:Psh I misconstrued the question along with mixing a few things up, just do a Change Distance event under the Camera category
Thanks, that worked! Although I have another question, but this doesn't really have to do with the view distance, but does involve the 3D mode. See, when I put a custom made model in the "body" section, I added collision to it, yet in-game I can just walk through the object. Is there something I'm missing?
PostPosted: Mon Nov 23, 2015 4:02 pm
by AnvilHouse
Are they on the same team? Is Solid checked?
PostPosted: Mon Nov 23, 2015 4:13 pm
by skullboy99
AnvilHouse wrote:Are they on the same team? Is Solid checked?
No the object is not on the same team, and the solid is checked. See, basically I'm trying to make a floating platform that moves around the map, and everytime I try to jump on it, I fall through the object. I'm not entirely sure if objects could move with the player, but I was still wanting to test it.
