MMO Template Starting Map
TomlinsonProductions
Postby TomlinsonProductions » Wed Feb 22, 2017 1:55 am
Hello, I cannot find where the template is storing the "Position Actors" event for the connecting players on the "Spawn" map. I would like to find where the script is so I can change the spawn point. Also I would eventually like to make multiple spawn points based on your faction how would I go about doing this? I know I would have to use variables. Thanks!
Re: MMO Template Starting Map
Postby Mr.Numbers » Wed Feb 22, 2017 7:25 pm
The current setup only allows for one initial spawn point. You have to set the "Starting Map" like any other 001 game in the "Game Settings".
From there though, you can say place the actor in a "Dummy Map" where you can place some scripting to move the character to any other map though if you needed to involve some more scripting.
