Delay actor movement & move with cursor
Danny
Postby Danny » Thu Feb 11, 2016 1:49 pm
Okay so need some help with movement of the main actor.
TOPDOWN TEMPLATE
I need the main actor to move only left or right based on the cursors location. I also need it so theres a slight delay in movement for both moving and stopping. I'm making a spaceship in space and when you move the mouse to the left or right i want it to sorta "Glide" in the direction and not just move instantly.
How would i set this up? Thanks :D
SBG
Re: Delay actor movement & move with cursor
Postby SBG » Thu Feb 11, 2016 5:37 pm
For topdown, just worry about the X value, subtract for left and add for right, or just have it match the cursors X, and keep your Y as the actors Y. I'm guessing you want to put this in a timer too.
For the movement you are looking for, simply apply acceleration to your actor, and use a lower value.
If you are using the Walk To event in a timer, it's pretty likely that acceleration won't always work like you want it to, since the actor would always be moving. What you want to do in that case is use a comparison branch at the start of your script, and if the cursors X position is X amount of pixels from the actors X position, do no Walk To. Pretty simple.
Danny
Postby Danny » Sun Feb 14, 2016 3:31 pm
SBG wrote:For topdown, just worry about the X value, subtract for left and add for right, or just have it match the cursors X, and keep your Y as the actors Y. I'm guessing you want to put this in a timer too.
Sorry I don't follow? I tried to check if cursors x is less than actor x if so move left, I x is greater than actor x move right, I'm getting nothing but strange movement.
Edit: BUMP!
Last bumped by Danny on Sun Feb 14, 2016 3:31 pm.
