Page 1 of 1
CPU and Memory Utilization
PostPosted: Mon Apr 03, 2017 3:16 am
by photocyte
Hi,
No matter what I do, I get a minimum of ~15% CPU usage with 96MB RAM for anything I run: the ARPG demo, even a new empty game.
I have a i7-4770k (not overclocked) with 32GB, and a GTX960
As a point of comparison on my PC, Undertale runs at ~2% of CPU and 280MB RAM
Another game engine (Clickteam) runs a basic 640x480 ~2% with 8MB RAM
Has anyone seen this before?
Re: CPU and Memory Utilization
PostPosted: Tue Apr 04, 2017 10:48 pm
by thebluejester
Out of curiosity which OS are you using? Is this 001 running in Windows or like Linux with WINE?
Have you tried a game that doesn't use the default assets?
I imagine that's where the 96mb of ram is coming from/why it's remained the same.
PostPosted: Tue Apr 04, 2017 11:45 pm
by photocyte
So I created an empty project which didn't have any assets and still got that number.
Although I'm not worried much about the memory too much, it's really the CPU use that concerns me.
PostPosted: Wed Apr 05, 2017 1:00 am
by thebluejester
So running Windows then?
Does your CPU dynamically clock itself? It could be giving different Utilization % at different clock speeds. Like 15% at 1Ghz Vs 2% at 2.4Ghz.
Is the editor running at the same time or just the complied game? Test that?
PostPosted: Wed Apr 05, 2017 1:45 am
by Mr.Numbers
I know 001 has some certain optimizations, and if I recall correctly, one lately that increases CPU usage but dramatically improves response time. Only thing is I can't remember if this was an editor optimization, a game optimization, or both.
Honestly the only person who is suited to answer this question is Mike.
PostPosted: Wed Apr 05, 2017 6:28 am
by thebluejester
I was hoping I could get as much information out as possible and then somone from the 001 team could give a proper answer. Haha.
Thanks Mr Numbers :)
Re that recent optimisation you can check the patch/release notes if you're interested photocyte.
I agree that CPU usage that high is a bit concerning, I'm worried about the impact on HTML5... Wish I had an old version to compare with.
PostPosted: Wed Apr 05, 2017 6:59 am
by Mike
What exactly is the concern here? Are you running into any specific problems or are you just worried about problems in the future?
PostPosted: Thu Apr 06, 2017 2:49 pm
by photocyte
Thanks everyone for your replies.
Mike, my concern is that as features are added the CPU usage will grow in an undesired manner. Say, for example, I have a huge map. Sure, the resources don't load until they are within X range, but how much CPU will the loader use? How many objects with fine collision can I have onscreen without tanking the CPU? Those kinds of concerns.
Thanks!
PostPosted: Thu Apr 06, 2017 3:08 pm
by Mike
I guess that's my point. CPU usage is not a good gauge of performance. You're best to monitor the framerate and other factors, which can be viewed in the stats debugger when playing your game.
You have no reason to be concerned. We're always here to help and if there's a really slow map in your game, all you have to do is send in your project for us to analyze. We can either make concrete suggestions or improve code in the engine.
So like I said, worry about it when there's an actual problem. And take a close look at the performance tips on our wiki for all of our recommendations: http://engine001.com/wiki/performance
PostPosted: Fri Apr 07, 2017 1:25 am
by photocyte
Okay man, sounds good. I appreciate all the feedback.
