Normal Maps supported?
evs
001 Admirer
Postby evs » Sun Jun 05, 2016 12:31 am
does anyone know if 001 Supports Normal Maps on 3D objects? seems like it would be a good way to get detail on a low poly object. i will try it out but i thought id ask the question too
AnvilHouse
Re: Normal Maps supported?
Postby AnvilHouse » Fri Jun 10, 2016 4:04 pm
yes normal maps are supported, they are also supported for tiles...you just need to switch to normal with your tileset
Image Image Image
https://www.patreon.com/Anvilhouse ...yes...I am on Patreon!
evs
001 Admirer
Postby evs » Mon Jun 13, 2016 11:29 pm
ok cool, thanks for answering.. havent managed to actually MAKE a normal map that changes the object in any significant way, but at least i know it should work if i do manage to. cheers
