Player turns invisible when I walk in a diagonal direction?
SabenStudios
Postby SabenStudios » Fri Oct 07, 2016 12:33 am
What'd I do wrong??
Zhuge
Insane 001 Forum Member
Re: Player turns invisible when I walk in a diagonal directi
Postby Zhuge » Fri Oct 07, 2016 2:28 am
Did you edit the upper right/lower right segments of the sprite's animation? Clear those images out and the problem should be resolved.
SabenStudios
Postby SabenStudios » Sun Oct 09, 2016 10:08 pm
Zhuge wrote:Did you edit the upper right/lower right segments of the sprite's animation? Clear those images out and the problem should be resolved.
I thought that too but it doesn't seem to be the issue, its doing it to all the sprites even the default ones I started with. Recently I've been messing around with the sprite layers like Face, Hair, Shoes etc. and adding more of them. I'm not sure if that could be causing the issue, but I'm not sure how I can fix it.
Last bumped by SabenStudios on Sun Oct 09, 2016 10:08 pm.
