3d model animation playing in blender but not in 001 creator
joihnsonlee
001 Supporter
Postby joihnsonlee » Mon Dec 18, 2017 10:34 pm
3d model animation playing ok in blender but not in 001 game creator?
any reason why 001 game creator is doing that?
also starting pose is different between both programs.
AnvilHouse
Re: 3d model animation playing in blender but not in 001 cre
Postby AnvilHouse » Tue Dec 19, 2017 12:02 am
Have you by chance changed any of the values in the properties Render panel?
I know blender likes to set the frame rate to 24 by default on new projects
Image Image Image
https://www.patreon.com/Anvilhouse ...yes...I am on Patreon!
joihnsonlee
001 Supporter
Postby joihnsonlee » Wed Dec 20, 2017 7:01 pm
my 3d model's animation's
frame rate is on 24fps
start frame is 1
end frame is 25
frame step is 1
why should it be something else?
AnvilHouse
Postby AnvilHouse » Thu Dec 21, 2017 2:16 am
it is quite possible that having your frame rate at 24 is causing some miscalculation on your frames, try it at 30...if that doesnt help, is it possible you have keyframes from object mode? (not using bones) as 001 doesnt support per vertex keyframes
Image Image Image
joihnsonlee
001 Supporter
Postby joihnsonlee » Thu Dec 21, 2017 6:45 pm
i tried 30fps but no luck
also i think the model i use (from "manuelbastioni") uses bones for their models
here is a link to show that they do use bones http://www.manuelbastioni.com/gallery_100_00.php
if anyone else has problems with manuelbastioni please tell me, at least i know i'm not the only one with manuelbastioni
