Animation framerate dependant on speed
Kraven4382
Postby Kraven4382 » Tue Apr 11, 2017 1:18 am
Hello,
I am working on feature that allows the character to "run" when shift is pressed. This will change the characters speed and also the animation played while the key is pressed. Because the speed might be different under certain circumstances I would like the animation to have a variable framerate dependant on the speed of the character at that moment. The default "Walking" animation works very well with varied speed but I need an extra custom animation that would also change the framerate dependant on speed. I imagine I could change the entire actor every time the player runs but this seems a bit sloppy. Does anyone know how to make a custom animation whose framerate is dependant on the speed of the character?
Thanks!! :)
- Kraven
Re: Animation framerate dependant on speed
Postby Mr.Numbers » Tue Apr 11, 2017 4:03 pm
Hmm, easiest option would be to just setup a second sprite and switch it out. The other way would be to use the "Play Pose(?)" custom event, the one that plays the animation once. This event allows you to determine the play speed of the animation. You have to run it in a loop though, and base the speed of the animation on the speed of the player.
Kraven4382
Postby Kraven4382 » Sun Apr 16, 2017 6:14 am
Thanks, I'll give it a try :)
