Actor 1-2 Pixels off the ground platformer
Danny
Postby Danny » Sat Sep 03, 2016 5:11 pm
I've noticed some rather odd visual? behaviour in my game. When i "Jump" while walking left of right my actor doesn't completely set back on the floor, it hovers 1-2 pixels above the ground and then after around 0.1-1 second it will drop back to the floor. When i jump up and down on the spot without moving this issue doesn't occur.
I've checked my collison on my sprite and all seems to be in order. I've also noticed this issue actually occurs in the 001 Platformer template as well with the default 001 platformer actors. Is there any way to fix this? It make my game look rather glitchy all the time while performing jumps as you walk.
Below is a screenshot. Thanks.
Edit: Anyone?
Edit 2: Still need help with this.
Edit 3: Had to copy/paste, no more bump option. Been over 7 days. Anyone??
AnvilHouse
Re: Actor 1-2 Pixels off the ground platformer
Postby AnvilHouse » Sat Sep 03, 2016 9:04 pm
Really i have no answer here...I dont experience this at all. Wish I had a better answer for you, no matter matter how much I try I cant get it like that XD
My suggestion is maybe delete the sprite then re-add it, usually fixes the problems i encounter in this area
Image Image Image
https://www.patreon.com/Anvilhouse ...yes...I am on Patreon!
Danny
Postby Danny » Sat Sep 03, 2016 9:21 pm
Tried it but still same issue, default 001 platformer does the same. :/
epsilon017
Postby epsilon017 » Tue Sep 06, 2016 10:03 pm
Does your game display any signs of lag or an otherwise choppy frame rate? I'm only going by a hypothesis right now, but I've had characters glitch through walls for that reason, and I've also experienced this same problem with some of my platformers.
Defenders of Sol (Demo): http://engine001.com/games/Defenders%20of%20Sol_3083.htm
I really have no idea what I'm doing.
Danny
Postby Danny » Thu Sep 29, 2016 4:14 pm
I always get lag in my games. Yes.
Edit: This is still happening in my game, also the 001 demos and recently Ramchuk sent me a demo of a random world generator and it also does the same in his demo which is also 2D platformer. Surely this is no longer a issue with my collision? My game, another members games and 001 demos... also may i point out this only happens after jumping when the main actor falls back to the floor, he simply doesn't "Reconnect" correctly to the floor.
Postby Mike » Thu Sep 29, 2016 4:33 pm
If you slow down the fall rate (for example, gravity) and/or set a minimum framerate in settings, it'll alleviate this problem.
Danny
Postby Danny » Thu Sep 29, 2016 4:42 pm
Mike wrote:If you slow down the fall rate (for example, gravity) and/or set a minimum framerate in settings, it'll alleviate this problem.
How would i slow the fall rate? The "Fall" section is greyed out in the player properties window, i know i can enable the fall window by selecting my player to "Fly" but am not using flying in-game. My frame rate is set to 30 (Minimum) i can go lower back to default 10 and see what the games like.
JimmySterylian
001 Fanatic
Postby JimmySterylian » Fri Sep 30, 2016 1:05 am
Like Mike said, try tinkering with the Change Map Gravity event and see what happens.
Danny
Postby Danny » Fri Sep 30, 2016 1:20 am
JimmySterylian wrote:Like Mike said, try tinkering with the Change Map Gravity event and see what happens.
Yeah. I read what Mike said... No difference...
Edit: I adjusted the velocity of the jump from 36 to 40 and seems to have fixed the issue for now as far as am aware. The gravity didn't help unless i used it wrong, i adjusted on the Z using a negative value.
If i run into more issues closer to release i will come back to this topic. Thank you everyone.
