001 Game Creator v1.020.003 Pre-Release
New version and premium template announcements for 001.
The release date of the next version is completely unknown. Predictions are sometimes mentioned around the site, but they're always inaccurate. We're doing this for fun, so we enjoy not having deadlines.
Due to lack of time, feature requests and suggestions are currently not being taken by non-subscribers at this time.
Creating topics in this forum section has been disabled. If you would like to post questions concerning GG Maker, please post in the appropriate support forum.
Postby Mike » Sun Jul 22, 2018 3:39 pm
This is a pre-release before others get it. Some new website links related to services will not function until we transition to new website; planning for early next week.
Countless bug fixes and some really nice cleanup to some features.
1.020.003
-Fixed crash when loading a saved game with an unfocussed map that has forced processing.
-Fixed crash when converting a sub script from textual to graphical.
-Made it error when DLC is not correctly installed when creating new projects.
-Properly made Android building target Android 8.0.0 (API level 26).
-Fixed cursor from incorrectly reappearing when loading a saved game.
-Fixed cursor from not reappearing when switching to one of the debugger sub-windows.
-Fixed landscape games on Android from crashing.
-Made field collection offset x/y scale when two sided edging is used (to mimic width/height and text size scaling).
-Added "Retrieve Position X/Y" options for fields.
-Fixed "Enable/Disable Input Set (Player)" event (old event will appear invalid).
-Fixed script debugger crash when scripts are being called recursively.
-Fixed delayed events debugger from sometimes crashing when there are delays inside an actor interface.
-Fixed crash when delaying something inside an actor interface's field trigger.
-Fixed scatter gun and resizing issues with Space Shooter.
-Fixed collision/walking bugs introduced in last version, by properly fixing flat actors going through the ground.
-Made it warn in log when projectiles instantly hit the ground, with a legacy option to disable it; will never show up in built games.
-Fixed "Actor Enters/Leaves Proximity" trigger producing a scripting error when a distance was not specified; in such a case, the distance is now assumed to be infinite.
-Applied smooth actor auto-climbing to event/AI-based movement and velocity based movements.
-Made actor auto-climbing higher when actor's speed is higher.
-Made bug reports still work when memory is low.
-Improved loading times of games with lots of scripting.
-Fixed crash with net debugger after prolonged usage.
-Fixed minimalistic saved games from loading with broken message boxes if a "Player enters" map script contained a message box event.
-Fixed HTML5 game resolution from not adapting initially.
-Fixed issues (including crashing) with delays inside actor interfaces when fields are spawned or destroyed.
-Made picking "(None)" from use value window in graphical scripter to properly reset resource, toggle, direction, rotation, range, color, time and speed parameters.
-Fixed clearing text boxes representing resources from improperly causing parameter to be skipped in-game.
-Fixed custom event / network message parameters from switching from "Number" to "Text" when changing default value.
-Made default text option for custom event / network message parameters show actual text, rather than modified text with underscores; to be clear, underscores and semicolons will continue to not be allowed for default text.
-Fixed "Shake Screen" event from not working on both axes in front view.
-Made "Lost enemy" actor trigger actually execute when an enemy is deleted or moved to another map.
-Fixed initial game launch time in HTML5 games (entire game's resources were originally being loaded all at once).
-Made "Current/Maximum Statistic" names more consistent across script and item editors.
-Renamed "Duration:" to "Transition Duration:" in all graphical scripter events to clarify the option's purpose.
-Made use of hand cursor for logo buttons.
-Fixed returning to post auto-movement from going off original route.
-Fixed AI actors not going back to post when enemy is too far (it was also not properly triggering "Lost enemy" in that case).
-Updated left hand panel to include more social media and new services.
PLEASE DO NOT REPORT BUGS IN THIS THREAD
Return to 001 Game Creator Announcements
